What is this? Where do these go?
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Ok i dont even know what to call this thing. All i know is that orange and pink wires come out of it and some wires plug into the fuse box. Is there a diagram showing where the the wires go and what they are? Also two of the wires are cut, are they important? Trying to put my interior back together this week. Need some help please.
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: What is this? Where do these go?
here's what you need to do.
You need to search these forums for the wiring diagrams for a 1985 Camaro matching your options.
Then, you need to look for a fuse block that has org/blk, orange, and pink going into it. If you don't find it, its likely added afterwards and you can probably ignore it.
The diagrams are on this site, you just need to search.
i had something similar in my 85 iroc, kind of like a jumper harness added in for something, it went to the passenger side of the dash to a relay that had a few cut wires, i just remove it all and put the wires where they went in the fuse box, used a haynes manual for wiring reference, couldnt find anything on it in the diagrams, good luck bud.
nice build
nice build
