Alternator voltage regulator bad?
Old Jun 17, 2013 | 10:19 AM
jbradhill's Avatar
Car: 1986 Camaro IROC Z28
Engine: 383 SBC
Axle/Gears: 3.75 LS
I replaced my 3-wire alternator which worked fine for ~1 day. The dash gauge showed that it was charging and a slight movement on the gauge as the motor reved. Then noticed the dash gauge was reading ~8 volts (right above the "red" lower limit on the guage.
Checked and found that the sensing wire had come disconnected. I have a battery kill switch, but forgot that the sensing wire was run directly to the battery. So I tried to reconnect and accidentally shorted betwee the alt case and connector and get a spark. .... disconnected the sensing wire at the battery, reconnected sensing wire, reconnected battery and now, I am still getting ~8 volts.
How can I determine if the voltage regulator got fried by my mistake?
Thanks! Brad
Old Jun 17, 2013 | 10:39 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Alternator voltage regulator bad?
Start the car and measure with a multi meter.
eightsixseven
Dec 16, 2024 01:50 PM
Cornholio7979
Sep 20, 2018 02:31 AM
GTAman
Sep 21, 2015 09:57 AM
mike_c
Aug 27, 2015 04:32 PM
