Check out this C100 connector... Melted?
Old Jun 23, 2013 | 11:56 PM
92CamaroLS1's Avatar
Car: 92 Camaro RS, 90 Camaro RS
Engine: 346 LS1, 305 TBI
Transmission: 4L60E, 700R-4
Axle/Gears: 10 bolt:3.42, 10 bolt:??
So I swapped a 98 LS1 into my 92 camaro (was a 5.0 TBI) and I had to do a lot of wiring to hook up the harness. I did the wiring when I was 18 and it was pretty bad so I recently decided to rewire it so a lot of soldering was redone. After I redid it I started having weird issues... Turning the lights on would cut the engine off, the speedo stopped working etc. so I disconnected the c100 connector just to look at it and it looked like this (pic added). I figured all of the soldering heated up the wires and melted the connector. But what I don't get is I never touched any of the body harness stuff and that side of the connector is like that too (can't see it in the picture with the cover still on). Plus theres this sticky grease like material all over everything. Is this normal? or is it melted? Could this be causing my electrical gremlins?
Chris
Old Jun 24, 2013 | 01:47 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Check out this C100 connector... Melted?
The black goo is factory, meant to keep water out afaik, as well as freak you out
Old Jun 24, 2013 | 07:02 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
yup, its a sealent. found on every c100 connector from the factory.
Old Jun 30, 2013 | 01:20 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Thats messier then usual tho LOL
Old Jun 30, 2013 | 10:57 PM
Haha ok thanks guys... I think they applied it that messy more to just freak me out than for any sealant properties. But now my hunt for the cause of electrical gremlins only gets worse
Bubbajones_ya
Jul 6, 2024 08:32 PM
BumpaD82
Feb 26, 2016 02:57 PM
skeltor
Feb 2, 2016 10:37 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
