HELP on Idenitfying the MULTI FUNCTION SWITCH
Old Jul 11, 2013 | 02:03 AM
Eric0840's Avatar
Car: 1988 Iroc Z
I need to know what a multi function switch looks like and what the usual price goes for it if you got a site for me to find one let me know, brights don't work but the clicker for everything els does work just not when I pull it back
PLEASE HELP on this one - Eric 1988 IROC Z 305 TPI (BLACK)
Old Jul 15, 2013 | 05:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Advance Information
You can find the one you need at Advance Auto Parts, as well as many other stores.
Happy Racing!
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
Old Jul 18, 2013 | 12:43 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Re: HELP on Idenitfying the MULTI FUNCTION SWITCH
so you're saying everything else associated with the multi-func switch works, just no brights? most likely not the multi-func switch, but a loose switch/rod on the sterring column for the brights... located on the column, down near the floorboard, about 10:00 position. if the rod has come out, that's a tricky fix, but just a loose switch is fairly easy...
Old Jul 18, 2013 | 01:14 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Even if it is the multifunction switch, you wont find a replacement for the piece you need in any parts store. The piece that would be broke in the column where the switch goes in is what actually pushes in the rod in the column, not the multifunction switch itself. The end of the switch just snaps into a plastic housing and the housing is what contacts the pushrod to move it. Only place you'll get another one is out of another steering column at a junkyard.
Old Dec 6, 2013 | 07:51 AM
Eric0840's Avatar
Car: 1988 Iroc Z
yeah well I haven't had to fix it lately for some odd reason it the brights work but now my right side fender light and turn signal doesn't work when I pull the light switch on I mean when I do it cancels the fog lights and automatically had the bright on soo annoying I get flashed every night after work..... I hate electrical
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
ericjon262
Sep 11, 2015 06:07 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
