best way to fix this plug/relay?
Old Nov 30, 2013 | 05:15 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
The pic is of relay by pass headlights.
Fan I rebpin this some how, figure I ask here befors I try to tear apart.
Old Nov 30, 2013 | 08:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: best way to fix this plug/relay?
Get a universal relay and replace it... That plug is too bad to save.
Old Nov 30, 2013 | 08:27 PM
Yeah, was afraid of that too....
Old Nov 30, 2013 | 09:25 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Clean them then temporarily use electrical tape. Straighten them out and cut 4 pieces of tape 1in. long. don't wrap them just lay the center of the tape lengthwise over the wire. Then just fold the tape over sticking both sides together.When you're done use the tape to keep them from touching as an extra precaution. Lay a piece of tape across the four wires .and push down.do the same thing on the other side.All 4 wires will be strate and separated.
Folding the tape over wires like that lets you work in tight places and is just easier and the tape does not unwrap like wrapping can.That procedure I just used on a fuel pump relay that looked like that and will last until I can fix it right.
Old Nov 30, 2013 | 10:42 PM
yeah definitely think I'll need to get new ones although I did think to do that as a temporary fix just wasn't sure what caused that kind of damage it almost looks like it was pulled out of the connector so I thought maybe it's something I could be repinned
both relate up by the passenger side headlight are like this and I'm assuming that they are for the headlight motors ?
Old Dec 1, 2013 | 12:07 AM
nova983's Avatar
Car: 1988 Trans Am GTA
Axle/Gears: 3.70
I had a what appears to be the same relay's socket fry from the previous owner and I just went to a junkyard and got the socket and relay with about six inches of wire and spliced it in. I haven't had any problems with it since. You just have to make sure that you use environmental splices so that the connections won't corrode. Also if they are both up by the pass headlight it should be for your cooling fans.
Old Dec 1, 2013 | 06:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If you are going to splice in anything from a junkyard ,get a weatherpak connector and relay from a later model car .
Never have problems again
This type
http://tpiparts.net/inc/sdetail/10962/3991
http://tpiparts.net/inc/sdetail/10959/699
Old Dec 8, 2013 | 11:16 AM
Pocket's Avatar
Car: 91 Trans Am
Yup, those are great. The newer bosch square relays are just as resilient and inexpensive, so you've got options
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
