89 bird headlight modules
Old Jul 26, 2013 | 06:23 PM
biglano's Avatar
Car: 89 formula
Transmission: 5 speed
today both modules quit working, they are stuck in the up position. The lights work, just the modules. I checked all fuses, don't see any blown.
\Any ideas?
Old Jul 29, 2013 | 04:57 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Slamming The Doors
You might have missed a fuse in a different location if so equipped.
You might have one here:
If that’s not the problem
Use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the headlight module terminal 1A yellow wire, then 1C brown wire, to see if they get power when you turn the headlights on or off.
The headlight module is a rectangular unit about 3" x 4" mounted in a bracket on the left side of the firewall.
It has two connectors.
The prong that sends power to the lamps is the same one that sends power to the door module.
Happy Racing!
They Want To Put HOW MANY TV Cameras In My Car?!?!?!
Old Jul 29, 2013 | 06:36 PM
biglano's Avatar
Car: 89 formula
Re: 89 bird headlight modules
tell me how much difference this makes?
if I manually close the headlights, they re-open when I turn the lights on. how likely is it that both motors/drives would go bad at the same time? I have replaced the inner nylon inserts before.
Old Aug 5, 2013 | 04:45 PM
NINÅ's Avatar
Transmission: 765R4
Slamming The Doors
When you turn the headlights off, power is supposed to be removed from terminals 1A yellow wire & 1G
brown wire of the module.
You can measure that to see if that’s occurring.
If it is use a voltmeter across terminals 2C & 2D.
Have a friend turn and off the headlights.
When he does that, does the polarity reverse?
Happy Racing!
“Help” Me Into The Wall This Week, I’ll Just “Help” You Into The Wall Next Week
jrdturbo
Mar 31, 2016 02:58 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
Eric-86sc
Sep 28, 2015 11:37 AM
tattmann
Sep 27, 2015 05:20 PM
