Where does this wire go?
Old Jul 29, 2013 | 03:09 PM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
On the 89 Camaro, the harness coming thru the firewall directly behind the passenger cylinder head. It goes to a plug (I beleive C105) Dk Green, Lt Green and Black on the firewall side and then you have two wires on the engine side of this plug. The Lt Blue with Blk goes to the Hi pressure switch on the compressor. The other is a Big Black wire??? Where does it go???
Old Jul 29, 2013 | 05:27 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Where does this wire go?
Got any pics of it as that will help us out to see what it is. to me it sounds like the HVac wiring but it seems like different coloured wires
Old Jul 30, 2013 | 08:47 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Transmission: 4L65E
Added a pic. I think I figured it out. During the LS swap I apparently did not include the Main power wire to the Blower relay and the ground to the blower moter. The black wire is the ground for the relay and blower motor. I can only assume it was back-feeding voltage to this ground, thus why it was showing 6v with A/C control on. I guess my question now would be is where to put this ground? Many places to to put it but I am sure one would be better than another. The hot wire to the relay looks to be sorced thru a fusable link (What size I don't know) directly to the starter or Battery.
So I will sum this question up.
What should be the Amp rating for the fuse to the blower relay and where best to ground the relay and blower motor?
Thanks in advance.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
