Speedometer not working at all
Old Aug 14, 2013 | 07:58 AM
domprim's Avatar
Car: 1992 Z28 Chevrolet Camaro
Engine: 350 chev- stock
The speedometer is not working at all in my 1992 Z28 Camaro. I checked the speed sensor and it seems to be fine. I have no clue what the problem is! Anyone else have this problem? If so, please help me
Old Aug 14, 2013 | 05:24 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Speedometer not working at all
How ?
Old Aug 14, 2013 | 06:31 PM
domprim's Avatar
Originally Posted by vetteoz
How ?
I got an auto electrician to check if anything was worn out ad to see if any power was still coming from it when it spun. All seemed to work fine.
Old Aug 14, 2013 | 08:00 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I got an auto electrician to check if any power was still coming from it when it spun. All seemed to work fine.
So on a 90 - 92 TPI car, the speedo signal from the VSS unit in the trans goes to the ECM first ,then the speedo in the dash cluster.
Pull the engine codes and see if there is a code 24 (VSS ) code showing.
If there is no code then it means the fault is after the ECM or with the speedo itself.
If there is a code them the VSS signal is not getting to the ECM
Old Aug 15, 2013 | 09:16 AM
domprim's Avatar
will do! thanks for the help
Frozer!!!
Jan 19, 2024 04:55 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
ChevyZ71
Aug 13, 2015 07:30 AM
marcusaw
Aug 10, 2015 08:13 AM
