starting problem
Old Aug 18, 2013 | 09:21 AM
rs30592's Avatar
Car: 92 rs
starting problem
I had the column out and when I put it back in the security light was on so I bought a bypass for it and that shut the light off and it still wouldn't start then I let it sit for a few min then it turned over and started. After I shut it off it wouldn't turn over after it sat for a while it turned over again and started. Then same thing again.
Old Aug 18, 2013 | 09:25 AM
rs30592's Avatar
Car: 92 rs
Re: starting problem
Could it be the starter relay
Old Aug 18, 2013 | 08:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by rs30592
I bought a bypass for it ... I let it sit for a few min then it turned over and started.
wouldn't turn over after it sat for a while it started. Then same thing again.
VATS has a timer, if it doesn't see the resistors or reads them wrong then you have to wait 4 minutes until you can try again.
Every time you turn the key , the timer goes back to zero.
Check the wiring on your bypass resistors to make sure you have a good connection there
Old Aug 19, 2013 | 09:44 AM
rs30592's Avatar
Car: 92 rs
i looked last night and i don't have power to the relay but i have power to the ignition switch on the column.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
