how do i get my trunk motor to stay up so i can lock it down
Car: 1988 Iroc Z
I replaced all the component's on the motor its self the when I tried to install it back in but some how its in the down position now my trunk can pop open if I hit a bump or rail road track... confused because before It was in the up position and I could lock it and unlock with no power to the unit.
Please help
1988 IrocZ28 305 TPI
Please help
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: how do i get my trunk motor to stay up so i can lock it down
is there power going to the hatch motor? if its all the way down it wont catch at all as I had the same issue over the winter when I pulled my battery and the hatch would never latch down properly. If need be you can adjust it with the 3 bolts that wold it to the body
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
right in the middle where the "hook" goes to lock down, there should be a "trigger" arm that if you bump it with a screwdriver, will reverse the motor in the "up" position so you can lock 'er down.
Car: 1988 Iroc Z
theres no power to the unit but if I were to screw it back in, can i adjust it manually?
Car: 1988 Iroc Z
there is actually power to the unit I can feel the motor move when I hit the trigger ive unbolted the whole device but still cant figure how to make it in the up position...
Car: 1988 Iroc Z
yeah but how do adjust it?
colton_carlson
Mar 8, 2019 12:21 PM
