tps not reading right value
Old Sep 2, 2013 | 08:28 AM
Youngs92's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TPI
Transmission: 5-speed
I've been trying to tune up my car, reset the timing, idle and tps, and the tps is giving me a problem. With a voltmeter, I verified that the ground for the tps is good (12v), the power is good at 5v, but the signal voltage is incredible low. With the tps turned all the way up the voltmeter only shows .04v. I swapped in another tps and am getting the same readings. Both tps sensors are working properly and show the correct resistances with no jumps. Anyone have any suggestions?
pjsparts
Oct 29, 2025 06:39 PM
J-money
Jan 4, 2019 09:45 AM
Linson
Sep 21, 2015 01:08 PM
TrevinE
Sep 14, 2015 03:20 PM
