Voltmeter, Low when hot, high when cold
Old Sep 5, 2013 | 08:47 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Did a quick search for an obvious answer but came up empty. I assume this is either a grounding problem or a bad gauge.
Volt meter reads low (around 8?) when hot, (summer, after driving car for a minute) and extremely high (almost maxed) when its real cold out. I have verified the voltage and it never really changes from 13.4 to 13.1
Anyone have similar problems with a solution?
J
Old Sep 8, 2013 | 12:32 PM
Keoman's Avatar
Re: Voltmeter, Low when hot, high when cold
Any Ideas?
Old Sep 8, 2013 | 02:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Sounds like the gauge if you verified the actual charging system voltage. either a magnet or the winding is bad in the gauge.
Old Sep 8, 2013 | 02:43 PM
Keoman's Avatar
I was leaning towards that, I shall order a replacement and see how that works.
Thanks!
Cornholio7979
Sep 20, 2018 02:31 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
E Rod
Aug 28, 2015 05:17 AM
jackhammer
Aug 15, 2015 10:04 PM
