Heater Fan not turning on
Old Sep 6, 2013 | 08:00 PM
Asim's Avatar
Hey guys,
First third gen. Had a 95 and a 71 Camaro in the past.
The switch for the AC / heater does nothing.
Which and where is that fuse. Is there a common problem?
Thanks in advance,
Asim
Old Sep 10, 2013 | 05:12 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Blowing It
First check the HTR A/C fuse located in the fuse block.
The fuse block is located up and to the left of the brake pedal, behind a small door.
If the fuse looks good, use a fused jumper wire apply power directly to the blower
+ terminal.
Did the blower run?
If yes use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the blower relay pin A red wire.
It doesn’t matter what position the ignition key is in.
Is there power on the
red wire?
If yes, jump pin A
red wire to pin E purple wire.
Did the blower run?
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
