Help with Ignition Toggle Switch
Old Oct 3, 2013 | 12:47 AM
CGMorrison's Avatar
Car: 1992 Z28
Engine: 355
I'm trying to wire up an ignition toggle switch and push button start on my project car. The ignition switch has been placed in the run position and disconnected from the ignition cylinder. I wired a toggle switch on the pink wire on the ignition switch. Flipping the switch on does everything that turning the key to the run position normally does. But when the switch is off I can just barely hear a humming and feel vibration from the alternator. When I disconnect the plug on the alternator it stops. Will this kill my battery if I let it go?
Old Oct 3, 2013 | 06:40 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Help with Ignition Toggle Switch
im not sure you have the right pink, there are a few under there. i would just intercept the pink at the dist, cut it there and wire your switch in to that. the starter button needs to be rated pretty decent current.
Old Oct 3, 2013 | 07:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
You would use the push button to operate the starter relay ( parts of VATS ); not direct to the starter
Old Oct 3, 2013 | 08:04 AM
CGMorrison's Avatar
Car: 1992 Z28
Engine: 355
I used the thick pink wire on my ignition switch. And of course I'm using the starter relay. My question was about the alternator. Anybody know what's up with that? I thought I had a fairly simple and defective killswitch and pushbutton start without the use of a key worked out until I heard that hum.
Old Oct 3, 2013 | 10:34 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
You'd have to switch the yellow wire from the ign switch, as well as the pink. The yellow feeds the alt exciter terminal via the resistance wire, and a couple of other things. The way you've got it, the alt sees the ign on permanently.
This diagram's for my '86 TA, but I'm sure yours would be something similar.
Old Oct 3, 2013 | 11:25 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
the cheap diagrams i was looking at dont show any of the start circuit, and mine didnt have vats fortunately.
and like i said you need to break the pink wire down the line further so you arent disturbing the alt. by the dist.
Old Oct 3, 2013 | 02:41 PM
Cosmik Debris's Avatar
The humming is the field circuit of the alternator, yes it will drain the battery.
Old Oct 3, 2013 | 03:16 PM
CGMorrison's Avatar
Car: 1992 Z28
Engine: 355
Awesome. Thanks for the help guys. I have it up and running now.
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
383cam
Sep 9, 2015 06:01 AM
Fronzizzle
Sep 8, 2015 12:10 PM
luvofjah
Sep 3, 2015 07:08 PM
