need to put some brains together guys!
Old Oct 5, 2013 | 04:15 AM
scarbucket's Avatar
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
ok here is what I got here I have a 3.1 that I have converted to a 350 .40 over carb I need help using exsisting wiring harness to set up for stock gauges if it is possible It was a tpi car so will it work if so diagrams and advice needed it will be getting a th 350 trans with a 2300 stall converter my car is a 1991
Old Oct 5, 2013 | 08:41 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: need to put some brains together guys!
Originally Posted by scarbucket
3.1 that I have converted to carb
What are you doing about the fans and fuel pump?
https://www.thirdgen.org/forums/carb...swap-help.html
https://www.thirdgen.org/forums/engi...v6-carbed.html
https://www.thirdgen.org/forums/post...533-post4.html
https://www.thirdgen.org/forums/post...691-post6.html
Also read
https://www.thirdgen.org/forums/engi...swap-read.html
will be getting a th 350 trans 1
https://www.thirdgen.org/forums/tran...eedo-work.html
Old Oct 5, 2013 | 03:48 PM
scarbucket's Avatar
Engine: 355
Axle/Gears: 3:43
keeping eletric fans and elec fuel pump
Old Oct 5, 2013 | 03:58 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I'd just like to know how he converted a 3.1 to a 350? lol
As said there's lots of information on here about engine swaps.
The gauges are all stand alone and don't need any other electronics to work. They simple connect to their respective senders for oil pressure, water temp, etc.
The only thing needing more work is calibration of the tach, a 6 cylinder tach will read high when connected to an 8 cylinder.
Jake_92RS
Jan 28, 2020 10:37 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
