Door Wiring HELP!
Old Oct 5, 2013 | 09:08 AM
Inpheksion's Avatar
Car: 1991 Z-28
Engine: 5.7L(350ci) TPI L98
Axle/Gears: G92
Door Wiring HELP!
So I'm at a swap meet and I just Bought a door off a 91 (I think) I'm trying to get the window rolled down with a jump box, but I don't know what color is what. What color should i hook up to ground and which one to hot? Any help is greatly appreciated!
Old Oct 7, 2013 | 04:43 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Window Of Opportunity
You didn’t say if it is the left or right door so these colors will be slightly generic.
If the window presently is up, connect the
brown wire to the + on the power supply or battery.
And connect the
to the black wire.
If the window presently is down, connect the
blue wire to the to the + on the power supply or battery.
And connect the
to the black wire.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
g.l.mos
Aug 22, 2015 12:02 AM
BlackTopKing
Aug 19, 2015 12:13 PM
