No power locks or dome light?
Old Oct 3, 2013 | 09:14 AM
LoganK's Avatar
I was removing the passenger side kick panel, under te dash, to see if there was a hole in the firewall that could be letting water pour in and pond on my passenger floorboard.
All I did was remove the kickpanel and inspect, and as soon as I got up to leave, no power locks or dome light etc. could I have bumped something under the dash to cause this? The only other thing I did was put the screws in the ashtray for storage and one rolled down into the cigarette lighter and I may have heard a slight "pop". Any ideas? The car still starts fine, just the accessory electronics don't work.
Thanks guys
Old Oct 3, 2013 | 09:38 AM
Yenipenny's Avatar
Car: 92 RS Heritage
Re: No power locks or dome light?
Thanks guys
The screw in the lighter is what screwed you. Replace the fuse and it will be fixed.
Old Oct 3, 2013 | 09:47 AM
LoganK's Avatar
Haha yep I kinda figured. Anybody know which fuse corresponds with what I need to replace?
Old Oct 3, 2013 | 09:53 AM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Either check your owner's manual (if you have one) as there is a fuse location diagram in it, or stick you head under the dash and look to see which one is blown. It will be the one with the burn mark on the glass or plastic.
Don't forget to take the screw out of the lighter socket before you replace the fuse.
Old Oct 3, 2013 | 10:32 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
There's a lighter socket in the ashtray?
Old Oct 5, 2013 | 06:05 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
My 84 has one right next to the Ashtray.
To the Original Poster, is the water "sticky" and does it sell kind of sweet? Water pooling on the passenger floorboard instantly makes me think your heater core went bad.
Old Oct 5, 2013 | 08:18 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
1) It's a 20 amp fuse. Can't remember which one it is, but happened to me and took a 20.
2) Water in pass floorboard is heater core.
Old Oct 7, 2013 | 04:44 PM
NIN's Avatar
NIN
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Logans Run
Yes, its the ACC fuse.
Happy Racing!
If Your Communications Antenna Is Not Shaking At Idle, Your Cam Is Too Mild
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
