positive battery cable routing question
Old Oct 9, 2013 | 03:03 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have an 84 Z28 and swapped an LT1 into it. I dont think the engine swap matters much since it is still a 350 small block (yes I had a 305 origionally). The problem is that I am ru nning some Hedman shroty headers and my positive battery wire to the starter keeps touching the headers and grounding out. Where should I run it?
Currently it runs beside the frame and then down to the starter. How can I place it so that it does not touch the headers. Can I run it under the headers completely from the front, near the engine mounts?
Old Oct 9, 2013 | 05:54 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: positive battery cable routing question
I run a BBC and I first run the positive cable through a section of hose and then next to the motor mount using zip ties to secure it along the way. Far away from the exhaust.
Old Oct 9, 2013 | 06:43 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
My battery is on the driver's side, so it may route a bit differently, but my cable is zip-tied to the front sway bar and the runs between my headers and the block to the starter. Haven't had any problems yet.
Old Oct 10, 2013 | 06:26 AM
Edwardgp's Avatar
Engine: 454-350
I run it through a rubber hose a little larger than the cable for extra protection.
Old Oct 10, 2013 | 07:29 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
i picked up a little longer cable and run it toward the oil pan first then tie wrapped down to the motor mount and then to the starter
Old Oct 10, 2013 | 07:31 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
I'd personally run the cable along the oil pan, using the oil pan bolts to hold p clamps. Route the wire around the back of the block, under the pan to the starter. This will keep it out of harm's way. But, if you drag race, you may have to protect the cable from the balancer IIRC.
Frozer!!!
Jan 19, 2024 04:55 PM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
