What the hell??
Old Oct 17, 2013 | 10:54 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
What the hell??
Can somebody please identify this relay/module? 86 TA. Mounted on firewall just to the left of the brake booster. I dont know if this is a factory positioning for this. The weatherpack was ruined by the PO and was hard wired in. The relay/module has 5 pins, but 4 are being used on my car. The wiring colors are red, light blue, black and the ground (on mine), is black also. Please help.. Thank you
Old Oct 18, 2013 | 09:08 AM
Copchaser's Avatar
Re: What the hell??
Update.. I just found out my harness seems to be that of an 88 car rather than an 86. So this was added to my car whenever that swap was made. Maybe this may help someone in helping me identify this part. Thanks
Old Oct 18, 2013 | 09:32 AM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
Re: What the hell??
When you unplug it, what doesn't work?
Old Oct 18, 2013 | 11:19 AM
J. Chris Davis's Avatar
Re: What the hell??
With only one wire going into it. I don't see that relay doing anything.
Old Oct 18, 2013 | 02:01 PM
Copchaser's Avatar
Re: What the hell??
Unfortunately, I cant answer that. I pulled the entire wire harness out of car for an overhaul, so I cant pinpoint that at the moment.
If you read the first post, there were other wires named that were involved with this relay.
Old Oct 18, 2013 | 02:08 PM
Re: What the hell??
Oh, sorry. I was in a hurry when I first saw it and only really looked at the pictures.
Old Oct 18, 2013 | 02:10 PM
Re: What the hell??
Could it be for MAP or Fuel pump relay? I don't know what you have for an engine.
Old Oct 18, 2013 | 04:38 PM
Copchaser's Avatar
Re: What the hell??
Its ok.. I figured it out. Went on ahead and took the relay off and held it up to the sunlight at an angle and was able to get the part number off it. Its the TCC module. Thanks for your efforts fellas
Old Oct 18, 2013 | 05:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: What the hell??
Originally Posted by Copchaser
Its the TCC module.
OK , I'll bite.
What does a "TCC module " do and where on the TCC circuit is it?
Typical GM 700R4 TCC wiring shown
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
92camaro350cci
Oct 14, 2015 09:29 AM
aaron7
Sep 30, 2015 09:15 AM
dimented24x7
Sep 6, 2015 03:51 PM
