Fan Relay...Green and brown Wire
Old Oct 18, 2013 | 04:25 PM
dmwracing42's Avatar
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
So on my '84, the green wire for the fan relay runs down into a four pronged connector which goes...to the waterneck I think. My engine swap is losing this water neck and going with a regular one without that wire connecter. The green wire looks like it comes off of its prong and then runs to the fan switch in the block. Can I bypass this connecter by running the green wire straight from the relay to the fan switch?
Second, the brown wire coming off the fan relay joins a connecter that attaches it to the brown wire off of the fuel pump relay, which then runs to the OPSU. I'm losing the fuel pump relay and letting the OPSU run the fuel pump. Will this cause issues for the fan relay?
Thanks guys
Old Oct 18, 2013 | 04:42 PM
Car: 1984 Trans Am
Engine: 355
Re: Fan Relay...Green and brown Wire
Alright well I figured out the green wire issue. In case anyone else happens upon a similar problem, the green wire runs to the 4 prong connecter, which runs to the AC, not gooseneck. It's wired that way so if the AC is turned on, the fan automatically goes on, but if the AC isn't on, the fan relay will be the source of the fan coming on.
Sorry for answering my own question guys, I tore the motor out without labeling things (stupid stupid) and now I'm trying to piece together what wiring I need as I go along.
Old Oct 18, 2013 | 06:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Thought of getting the FSM for your year that has all the circuit diagrams ?
Old Oct 18, 2013 | 08:58 PM
Car: 1984 Trans Am
Engine: 355
Getting tired of answering my wiring questions lol? To be perfectly honest, I went to austin third gen or whatever that site is and looked at the wiring diagrams. I had trouble following them though.
At this point I'm thinking I know most of what I need, most of the stuff is falling into place, though I still have the odd question here and there.
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
krisner89
Oct 10, 2015 06:03 AM
db057
Sep 4, 2015 07:57 AM
thefirebirdm@n
Aug 25, 2015 05:21 PM
