Wiring help need color codes.
Old Oct 20, 2013 | 12:53 PM
84firebird1996's Avatar
Car: 1991 Trans Am GTA
Engine: LT-1
HEre are some pictures of the wires i have left over since i eliminated the lt1 wiring harness. need to know the water temp sensor wire, tach wire, oil pressure, i already hooked up my starter and i also need to finds the fuel pump wires I deleted the relay and im going to install a switch inside the vehicle to power on and off the fuel pump and also the fuel level wire. Thanks 1st picture wires are running into cab and second pic are the wires from the fuel pump relay
Old Oct 20, 2013 | 04:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Wiring help need color codes.
Since your car never came with a LT1 from the factory would be more relevant to mention what it originally was ; TBI /TPI .......
https://www.thirdgen.org/forums/post...937-post3.html
Old Oct 20, 2013 | 04:38 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is better to run the pump relay off a switch , not the pump directly.
Old Oct 20, 2013 | 04:57 PM
Engine: LT-1
tpi
Im about to order a fuel pressure regulator bypass/return style
1 port inlet, 1 port outlet and 1 port return
will this work for my setup?
I have a stock 91 trans am airtex fuel pump which puts out around 40 psi and i need to regulate it down to about 7 psi.
http://www.jegs.com/i/Holley/510/12-803BP/10002/-1
Linson
Aug 21, 2015 02:12 PM
LT1Formula
Aug 20, 2015 09:36 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
87350gtanj
Aug 8, 2015 10:32 AM
