Two wire power antenna to three wire oem relay
Old Nov 10, 2013 | 07:05 PM
mav75's Avatar
Car: '89 Trans Am
Transmission: 700 R4
I just bought a power antenna with a red wire, a blue wire, and a ground wire. Problem is I have the original relay wiring with white, green, and grey wires.
Do you just connect the red to white, the blue to the grey, and leave the green wire alone?
Old Nov 10, 2013 | 07:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Two wire power antenna to three wire oem relay
Doubt that would work , , you would only have power in with no ground path
Would appear green is the common ( ground ) back through the relay
See
http://92b4crs.tripod.com/86wiring/dia-pics/151-0.jpg
Old Nov 10, 2013 | 07:59 PM
mav75's Avatar
Car: '89 Trans Am
See
I thought about that, but the instruction manual said to ground it to the chassis (it has a black ground wire), so I figured grounding it to the chassis would make the green redundant. Do you think I should connect the black ground wire to the green? I guess it seems to make the most sense.
Old Nov 10, 2013 | 11:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
One way to fine out
Wire it up according to the instructions and see if it works
If you look at the factory diagram it goes up with power on the white and ground on the green.
To go down it puts power on the green and ground on the gray to reverse the motor
BRoss99
Aug 10, 2025 05:08 PM
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
Caspar
Jun 19, 2016 11:19 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
