Take pic of park and fog lamp connector
Old Nov 12, 2013 | 06:03 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
I need to replace my parking lamp and fog lamps. PO cut them out.
Looking at the schematic it appears the fog lamps are 2 wore and the park lamps are 2 wire but maybe a 3 wire with 1 wire to ground?
Anyone have images of the fog lamp socket,wire and bracket same for the park lamp?
I have new light housings and not sure which ones to buy from autozone to fit.
Old Nov 12, 2013 | 01:51 PM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: Take pic of park and fog lamp connector
In order to give you good advice there needs to be a little more information on your part. What car are we talking about; Camaro or Firebird? What year is the car? Circuits and wire colors changed a bit throughout the model run. With that information you will probably get some pics.
Old Nov 12, 2013 | 02:04 PM
jjcuff1's Avatar
SOrry
1988 Iroc Z auto lb9 305
It has the fog light options. So looking for the fog light connector and bracket moutning
The park/turn lamps are missing. I think these are all the same 82-92 so just picture of the mounting bracket and bulb socket.
As for socket and type. Well that is why I need a photo they are missing so I dont know what they look like
but I assume they are brown and blue with black ground for the turns
and 2 wire purple and black for the fogs
Old Nov 12, 2013 | 03:14 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by jjcuff1
The park/turn lamps are missing. I think these are all the same 82-92....
85 to 92.
Maybe some help on wiring/colors in the following link:
http://www.austinthirdgen.org/index.php?pid=19
JamesC
Old Nov 14, 2013 | 09:51 AM
jjcuff1's Avatar
Thanks.
I went to a salavage yard and cut some turn harness from late 90s blazer and grand prix. they both are 3 wire black blue brown and appear to have teh 2057 bulb. One is is teh press and turn in bulb socket and one uses the wedge style. Figure try both see which one works better or has the better bulb selection (for led)
I cut the fogs from a late 90 grand am. 2 wire scoekt that uses a 880 or 884 style bulb that plugs directly into the harness socket and the bulb itself mounts into and twist into the housing.
I will check tonight to see if it all works and lines up.
Next will be mounting my the housings. All is stripped out of my car it appears. My turns have a mounting post on the back not sure how it screws into the bumper
the fogs have a universal l bracket that I guess I can bolt to the frame some how.
BRoss99
Aug 10, 2025 05:08 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
1992Vortec
Aug 31, 2015 08:05 PM
TheExaminer
Aug 26, 2015 04:59 PM
