Tachometer and LED gauges Fix
Old Nov 14, 2013 | 09:56 AM
jjcuff1's Avatar
Car: 1988 Iroc-Z Red T-tops
Engine: 305 TPI LB9 55k miles
Transmission: Auto 700r4
Axle/Gears: 2.73 posi
Well I pulled my gauge in a 88 iroc auto.
I pulled that yellow covered circuit board first on the back of the housing but then realized the fix I have seen here is for the tach itself. So I pulled the tach out and saw the 1-14 pin chip.
I checked the 4-10 Resistance and it was open. SO I wired 2 100k ohm resistors in series to the 2 points and put back together. I will install it tonight. I figure just try something using all others experience here that around 190-200k ohm seems to fix the tach. I think I did a poor solder job but I get around 194k ohm across the points now.
the tach pegs out at 7k immediately so I figure whats the worse happen?
I also cleaned all the surfaces and then installed 4x LED in all the bulbs.
Cross my fingers.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jk_Under
Sep 8, 2015 08:13 AM
Glowsock
Sep 6, 2015 06:40 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
