Speedo quits working sometimes
Old Dec 3, 2013 | 05:21 PM
Rich92 RS's Avatar
Car: 86 IROC-Z
Engine: 370 LQ9
Transmission: T56 Magnum
Car is a 92z with a L98 and 700R4. The speedometer will sometimes stop working and the car starts running like crap. It'll come back and go out aswell. It doesn't happen all the time, so Im wondering what it could be.
Only code was a 33, so i'll be looking at the MAP sensor tomorrow but im pretty sure thats unrelated.
Old Dec 3, 2013 | 05:56 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Speedo quits working sometimes
Originally Posted by Rich92 RS
Only code was a 33,
If you don't have a code 24 VSS error code
http://www.chevythunder.com/vss_code_24_sd_199092.htm
then your problem is likely the speedo or the wiring to it from the ECM.
In your car ,the VSS input goes to the ECM 1st , then the speedo signal is outputted to the cluster
Old Mar 5, 2014 | 09:42 AM
B1CrwDwg's Avatar
Car: 1991 Z28 Convertible
Transmission: Auto 4L60
Great info here:
https://www.thirdgen.org/forums/elec...ml#post5725338
92camaroJoe
Jul 29, 2023 07:57 PM
Jorlain
Aug 24, 2022 05:11 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
