Power window relay upgrade
Old Dec 18, 2013 | 07:53 AM
RaysUpRacing's Avatar
Car: 84 Camaro Berlinetta
Engine: 350 bored and stroked
I've tried to do a search here on this but could not find anything. Has anyone ever seen this or installed this? Does it work? Is it worth the money? Any info would help.
http://www.ebay.com/itm/1982-92-Camaro-Z28-Firebird-TA-Power-Window-Relay-Upgrade-/390723282225?pt=Motors_Car_Truck_Parts_Accessories&hash=item5af8ec2531
Old Dec 23, 2013 | 12:31 AM
lordmalice76's Avatar
Car: 1991 camaro rs
Axle/Gears: stock
Re: Power window relay upgrade
i dunno. you could make the same circuit with a couple of door lock relays from other gm vehicles. a trip to the bone yard is way cheaper than that.
Old Dec 23, 2013 | 04:26 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Looks interesting.
Old Dec 23, 2013 | 07:16 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Relaying Information
I’m not familiar with that brand however using relays for the windows will bypass the thin wires which cause the windows to move slower than the motors are capable of.
The idea is to run larger gage wires than stock into each door to deliver full system voltage.
Typically you would use 2 relays in each door, so instead of the window switch directly applying power to the window motor, it applies it to the UP or DOWN relay, then the relay applies power to the motor.
Happy Racing!
I Don’t Mind Wreckin’ On The Track, No Paperwork To Fill Out
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
zayne0
Aug 24, 2015 07:22 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
