No Headlights. No High-beam indicator. Everything else good.
Old Dec 18, 2013 | 07:23 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Yupp.. So Im messing with the high beam switch.... and BOOM got headlights.... get home, hit the High beams and wooosh gone for good............ cant get em back on again..... Thinking its the Multi-function switch. But Ive NEVER heard or had to replace a these older GM multi-function switches.............. Any help or helpful comments is greatly appreciated...
Old Dec 18, 2013 | 08:07 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: No Headlights. No High-beam indicator. Everything else good.
Probably the dimmer switch. Easy to replace and not expensive but buy a good one or you will be replacing it again real soon.
Old Dec 18, 2013 | 08:19 PM
Car: 1991 Camaro RS
is that what i keep reading about? half way down the column? Or the Headlight switch it self?
Old Dec 25, 2013 | 11:23 PM
Car: 1991 Camaro RS
Okay. I hate searching and finding the same problem but no actual Answer to the fix. So..
The High/Low Beam switch on the Column.. the Wiring harness to the switch. one of the wires had backed out of the connector just enough..... So i pulled the wire out, tweaked the connector piece so it wouldnt back out again too soon haha but thats all it was.. no parts were bad..
RS Reaper
Oct 17, 2018 07:52 PM
nova983
European Region
Nov 2, 2015 12:15 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
85cmroz28
Oct 4, 2015 09:44 PM
327IROC85
Sep 23, 2015 12:11 AM
