Need C210 info
Old Dec 26, 2013 | 02:14 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Need C210 info
I'm in the middle of a wiring fiasco with my car, I have a firebird service manual, but I can't find a detailed pinout of the C210 connector. Can anyone help me out? Any help would be greatly appreciated. The car is a 1988 trans am.
Old Jan 1, 2014 | 10:25 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Need C210 info
Let's see... C210 is the turn signal switch connector. In my 87 FSM, the pinout is on the page with the C207 on the left and the C208 above it, 8A-202-3.
There are no A B or C.
DEFGH-JKLMNP, left-to-right, 5-pin half on the left. No wire colors given, they will be in the Exterior Lights diagram, so you might want to write them down.
D:
E:
F:
G:
H: Light Blue: Output to LF turn lights
J: Dark Blue: Output to RF turn lights
K: Brown: Feed from hazard flasher
L: Purple: Feed from turn signal flasher
M: Yellow: Output to LR turn/brake lights
N: Dark Green... Output to RR turn/brake lights
P: White wire... Brake light cutoff wire from C208
I don't see any mention of D-G.
Old Jan 3, 2014 | 07:46 PM
alex722607's Avatar
Ok thanks that helps a lot
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
