driver door power lock not working?
Old Jan 2, 2014 | 10:26 PM
mikey8494's Avatar
Car: 1986 camaro iroc z
Axle/Gears: stock
ok so ive searched it and nothing realy to my specific situation so yea . so i had to remove my driver door awhile back to redo a hinge that had split in half and oncei reinstalled it the driver power lock will not work i push the button. i hear the pasenger side and the relay just not the driver side its weird any help is greatly apreaciated and yes i check if its pluged in and it is.
Old Jan 2, 2014 | 10:43 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Re: driver door power lock not working?
Make sure the connection on the actuator and switch are clean. They are terrible for bad connections. Pop off the terminals and give them and the motor/switch a good cleaning. If the passenger side is making the relay pop, it isn't the relay.
Old Jan 3, 2014 | 07:34 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
and make sure you have a good ground...
Old Jan 3, 2014 | 09:51 AM
mikey8494's Avatar
Axle/Gears: stock
thanks guys wil ltry
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
