88 GTA, digital controls no blower function.
Old Jan 9, 2014 | 01:09 PM
sheikss's Avatar
Car: 88 Trans Am GTA
Axle/Gears: 12 bolt 3.73
Looking on here is seems as though this ac setup is different from the normal system. The blower motor doesn't work at all. I did test the blower by sending power straight to it and it worked. I assume I can follow the same trouble shooting procedures found on here while searching. What are the common causes for this and do I need to do anything different for trouble shooting?
Old Feb 9, 2014 | 02:07 PM
sheikss's Avatar
Re: 88 GTA, digital controls no blower function.
So I got my test light out and did alittle trouble shooting. Under the hood on the hvac box on the grey connector I have power to all the wires no matter what position the fan speed switch is in, except off. When in the off position I have no power to the connector. On the relay, as I toggle from low to high, once I get in the high position you can hear it click. I have power on the a and b terminal, nothing for c and d. I put a ground wire on the blower motor and that didn't fix it either. What and where are the next items to check. There where no blown fuses on the block on the drivers side of the dash.
Old Feb 9, 2014 | 02:12 PM
sheikss's Avatar
At no time do i have power to the purple wire going to the blower motor.
Old Feb 9, 2014 | 06:55 PM
sheikss's Avatar
76 views and no ideas or help guys?
Old Feb 9, 2014 | 10:01 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
There are 2 relays, hi & lo speed, not sure which one you are checking. Attached diagram for 88 digital cluster should help you find the break. I would probably start at the blower motor resistor, if you have 12v at the brown/white wire, suspect the resistor is bad.
File Type: pdf
Old Feb 11, 2014 | 05:23 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here is some recent info I posted about the 'C67' (Digital Dash) 88 GTA Heater/Blower system.......
https://www.thirdgen.org/forums/post...80-post33.html
Here is the full Thread,..... Just stay focused on the Ditial Dash GTA specific info !
https://www.thirdgen.org/forums/elec...-resistor.html
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
