Charging System on the Fritz - New Wiring Subharness?
Old Jan 13, 2014 | 12:43 PM
Jaron Widman's Avatar
Hey guys. Long story short, last year I rescued an '85 Trans Am and have had continuing problems with the charging system. At this point, I've replaced the battery, the alternator (twice), and even butt spliced in a replacement electrical connector on top of the alternator (which had some corroded wiring), but still, the problem persists. It's strange, too. I'll start the car, and the multimeter reading at the battery will show anywhere from 13.5 to 14.5 volts while idling, but as soon as I rev the engine, it drops down to 12.5 volts and does not give me any more voltage unless my foot is on the pedal. I put the second alternator in yesterday and don't know what else to do. I think the next step is to put in a new wiring subharness between the battery and the alternator. Does anyone know where I can buy that? I've been searching around on the web, but no luck.
Old Jan 20, 2014 | 10:13 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Underdrive Jive
Does you engine have underdrive pulleys?
If yes, that causes that problem.
However as long as it is charging when you’re on the loud pedal, you don’t have a problem.
Happy Racing!
I’m Going To Win All My Races In 2014 . . . . . . . . . Or Not
midge54
Dec 27, 2019 04:14 PM
Caspar
Jun 19, 2016 11:19 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
