1985 L98, tach is messed up - MSD Coil
Old Jan 29, 2014 | 11:01 AM
DanielRicany's Avatar
Hey guys, I recently installed a MSD coil in my 1985 Corvette with the digital dash, I come here because people aren't as active on Corvette forum as they are here when it comes to this stuff.
Anyway, when I installed the coil, if I revved the engine, the tach would not go higher than 2600 RPMs, but you could hear the engine revving higher than that. If I slowly brought it up passed 2600 RPMs, it would display the actual RPMs.
I called MSD and they told me to bypass the tach filter, so I did, now when I turned the car on the whole electronic dash cluster was flickering and it was impossible to read the RPM reading, or even anything else on the cluster. I'm going to install the tach filter again, but I was wondering, what can I do to fix this problem?
Thanks!
Old Jan 29, 2014 | 11:17 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: 1985 L98, tach is messed up - MSD Coil
Did you try a MSD tach adapter? You could also try a 10K resistor in series with the tach wire.
morrow
Jan 13, 2024 12:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
