Dash connector pinout
Wire harness is from a 1987 iroc 350 tpi auto. Need pinout for this connector, I know its for injectors and cooling fan, but dont know what wire goes where and if it should have any power to it or not.. swapping this into a 1993 gmc k1500 and nothing in the dash matches this.m
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Dash connector pinout
That's C221,.... For 87' the wiring should be:
A Pnk/Blk Inj2 Fuse / Even Fuel Injectors
B Lt Green Back Up Switch / BU Lights ( V6-T5 )
C Brn Fuel Pump-Fan Fuse / Fan Relay ( V6 - TPI )
D Pnk/Blk Inj1 Fuse / Odd Fuel Injectors
E
F Dk Blue Back Up Fuse / Back Up Switch ( V6-T5 )
E
