Alternator fan loose
Old Feb 2, 2014 | 02:56 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I've got some strange noises coming from what seems to be the alternator. My question, is the small fan on the front of it supposed to turn by hand? Although not very free, it turns both ways.
Old Feb 5, 2014 | 02:26 PM
oaklandfuelman's Avatar
Car: 85 iroc z
Engine: 355 tpi
Transmission: 7r4
Re: Alternator fan loose
nope not unless your turning the engine over along with it or the fan & pully together are spinning around & that would just be a loose belt & i doubt thats what you are saying the nut that holds the pully & fan is suposed to be put on with an impact if it was changed at some point from an old alt to a new one it might not have been put on correctly no point in trying to tighten it by hand it will eventually come loose again if you cant get an impact on it take it off the car & do it or take it up to someone that has one & have them tighten it for you left alone it will more than likely get worse & at some point your more than likely gonna loose your pully & fan off the alt & then the belt so everthing that it drives like the water pump & your basicly stranded waiting for a tow truck
Old Feb 10, 2014 | 05:54 AM
Car: '92 RS Camaro
Transmission: TH400
Thanks for the reply The alternator is off the car now, and yes the whole fan and pulley are rattling around loose. I've got a replacement one coming now.
92firebirdguy
Sep 1, 2016 07:53 AM
codeysabatini
Nov 10, 2015 04:07 PM
sahlomonic
Sep 20, 2015 07:15 PM
64goatman
Sep 9, 2015 01:09 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
