Carbed 1991 Camaro, Computer removel questions
Old Feb 9, 2014 | 02:34 PM
datraum's Avatar
Car: 91 Camaro RS
Engine: 383ci, Holley 750cfm carb
I have a 1991 Camaro RS, I put a carbed 383ci in it a few years ago and I am trying to clean out some of the wiring.
Here's my setup:
No a/c
Carb with Holley electric fuel pump wired independently
Msd ignition box and distributor
No factory gauges are being used
Stock year 700r4 tranny with a non lockup convertor
aftermarket one wire alternator
My question is can I just remove the computer and all wiring leading to it or is there something it still does? I do understand I will have to bypass the VATS but I have already researched how to do that but could not find much on the 90-92's as far as just taking everything computer related out.
Thanks in advance for any help, Dave
Old Feb 9, 2014 | 02:39 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Carbed 1991 Camaro, Computer removel questions
The speedo still needs the computer to process the output from the VSS in the trans. It also controls the radiator fan, unless you already have it on a manual switch or an aftermarket fan switch. I didn't see that mentioned in your original post.
Old Feb 9, 2014 | 02:50 PM
datraum's Avatar
Car: 91 Camaro RS
Sorry I forgot to mention I do have aftermarket fans wired to a switch, and my speedometer hasn't worked in years so I'm going to put in an Autometer gps unit and get rid of the factory cluster.
84z96L31vortec
Aug 20, 2017 12:16 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
