Question
Old Feb 17, 2014 | 12:51 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Question
I have a 1991 Camaro rs with a 305 one day the speedo was workin fine then next it started not workin..... Now it works when it wants to anyone know what the problem is an the solution to fix it?
Old Feb 17, 2014 | 01:28 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Question
Check the speedo cable, see if it's loose or something.
Old Feb 17, 2014 | 01:53 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: Question
If the speedo cable isn't loose then the spring that holds the drive gear in the rear section of the trans may have worked its way off.
Old Feb 17, 2014 | 03:35 PM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: Question
Wut if it's not the cable? Is the sensor on the trans wut ur talkin about?
Old Feb 17, 2014 | 04:43 PM
jharrison5's Avatar
Car: '87 IROC
Re: Question
There is a gear on the tail shaft of the transmission which is held there by a spring. That drives another gear, which on a cable driven car goes to the speedo, or to a sensor that sends a pulse. It all depends on the type of trans you have. You didn't state in your first post whether you have a manual or automatic.
Old Feb 18, 2014 | 10:12 AM
$A_Money$'s Avatar
Car: 1991 camaro
Engine: 305 tbi
Transmission: auto
Re: Question
im sry its auto...
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
