power windows, rear hatch switch, wipers
Old Feb 21, 2014 | 04:26 AM
blp226's Avatar
I have a 92 V6 Camaro. The power windows, hatch switch, wipers and radio do not come on. The radio isn't getting power. The wiper motor isn't getting power. I don't know if the window and hatch switches are getting power or not. I checked all fuses in the fuse box that is located in the kick panel near the clutch pedal and they are all good. Is there some other gizmo that all of these things have in common or are all of these completely separate issues?
Old Feb 25, 2014 | 05:37 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
The Gizmo Is Connected To The Thingy
Sounds like you blew a Fusible Link.
Fusible Links usually look like a one inch plastic rod in line with the wire and are located near the battery or at the starter.
Use a bulb or meter to probe both sides of the links to find out which one went bad.
Happy Racing!
If My Engine Has An Illegal Part, And The Inspector Doesn’t Hear It, Does It Make A Sound?
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
z28addict8490
Aug 7, 2015 08:48 PM
