Prom?
Car: 86 Camaro Coupe
Engine: currently building a 355
Transmission: unsure what it will end up with
Axle/Gears: 10 Bolt 2.73
Prom?
I am switching from my V6 2.8L T-5 to a carbed V8 355..... do I even need my Prom or PCM? I took out the wiring and the prom and don't see any reason any my wiring diagram of why I should keep any of it except the battery and starter solenoid wiring.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Prom?
Nope ! Unless your state mandates that the car is factory for smog purposes,... you'll be fine with no ECM.
FYI; You WILL loose TCC lock-up, so an aftermarket lock-up kit is recommended.
Re: Prom?
Thank You for the information. It is greatly appreciated. Now I just need to figure out what to do with this thing.
