Blinker help
Old Mar 17, 2014 | 07:58 PM
Nolan92RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 v6
Blinker help
So I am having a problem with my blinker and it only works when it wants to. When I turn on my right blinker it will lock into place but it won't blink. When this happens no signals show up on the dash but when I look on the outside of the car the right rear blinker stays on constantly and the right front doesn't come on at all. It all works fine when I turn on the hazards. Again this doesn't happen all the time, only on occasion. Any help is greatly appreciated!
Old Mar 17, 2014 | 09:42 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: Blinker help
my guess is the signal switch in the column went bad
Old Mar 17, 2014 | 09:58 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: Blinker help
Check all grounds ,make sure they are solid. Also all other connections in the light harness . Might also try and put some doe electric grease to help the current flow better
Old Mar 18, 2014 | 07:22 AM
Nolan92RS's Avatar
Car: 1992 Camaro RS
Engine: 3.1 v6
Ok I'll check up on those and come back if I have any more questions. Thanks!
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
