85 TA Overhead Console Rear Interior Light Switch Not Working
Old Mar 18, 2014 | 08:18 PM
FL TA's Avatar
Car: 1985 Pontiac Trans Am WS6
Transmission: 4 SPD AUTO Borg Warner 9 Bolt
I put new bulbs in my overhead console and they worked fine.
The map light push button switch turns on and off the map light.
The rear interior push button light switch does not turn off the rear interior light. The light remains on.
Is there:
A. a replacement push button switch available?
B. would I have to grab a push button switch from another console?
C. can the bad push button switch be fixed someway?
Thanks!!
Old Mar 19, 2014 | 05:01 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 85 TA Overhead Console Rear Interior Light Switch Not Working
Is your door open??It won't go out if the door is open.
Old Mar 19, 2014 | 08:19 PM
FL TA's Avatar
Manta, both doors are closed and the light remains on.
Now even the freaking dome light is staying on also.
I think its related to my bad door jamb switches.
I just pulled the bulbs until I have more time to figure it out and get my new door jamb switches installed. It's great having a pitch black interior.
Doesn't the rear interior light in the console come on and off with the door jamb switch? And doesnt the door jamb switch override the push button switch?
Not sure about the dome light though. Seems that would be independent of the door jamb.
Old Mar 19, 2014 | 08:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by FL TA
Doesn't the rear interior light in the console...
Not sure about the dome light though...
I'm confused (happening more and more these days). There's the map light and dome light. What's not working?
JamesC
Old Mar 19, 2014 | 08:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
{ Doesn't the rear interior light in the console come on and off with the door jamb switch,Yes
{ And doesnt the door jamb switch override the push button switch?
NO.
You don't have the light switch in the on position do you??
Old Mar 19, 2014 | 08:42 PM
FL TA's Avatar
Here's a review:
I removed the console, cleaned it up a bit and bought new bulbs because when I bought the car neither was working from the push button switches.
I got into the car, closed both doors and put the console back in the car, inserted the new bulbs and had immediate light from both front and back lights as soon as I plugged the wire harness in. I tested the push button switches then. The map light (what im calling the dome light) worked properly and turned on and off with the push button.
The rear interior light did NOT turn off with the push button switch. Its staying on no matter how many times I push the button.
However, now the front map light is doing the same. It wont go off using the push button switch.
GRRRRRRRRR. Electrical gremlins, worse than any engine problem.
Old Mar 19, 2014 | 08:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Is it possible you switched the plugs?or have them reversed?(not familiar with the wires under their)and check and see if the interior light(dimmer Wheel) switch isn't in the on mode.
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
