No Contact or Voltage at all
Old Mar 15, 2014 | 12:54 PM
Renier's Avatar
Car: '89 Camaro RS
After swapping the old 2.8 engine for a better 2.8 engine which is almost entirely the same except not broken I'm experiencing that I have no contact at all when the key is turned in the slot and also there's absolutely no voltage to be measured on any plugs or anything inside of the car except for on the constant voltage that goes to the starter. Now it's probably a stupid problem and I hooked everything I could up but it's frustrating me to no end, it's not the battery because sparks are still flying off of it. Any suggestions as to what it could possibly be? I searched far and wide for lose plugs even under the car but couldn't find any any more. Anyone maybe have some charts or something which I could use to determine what's not the problem and what else isn't and so on until only the thing that is the problem remains? Thanks in advance, guys, and I do know it's a kinda stupid thing I'm overlooking but would really really appreciate all the help I can get with this, hearing my dear car's engine roar and being able to drive it around and show it to people is long, long overdue.
Old Mar 15, 2014 | 03:00 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: No Contact or Voltage at all
Have you checked fuses? What do you mean by sparks flying off the battery??? I sure hope you aren't touching cables or battery posts together!! If you've never had a battery explode, that's certainly a way to experience it. Have you checked the ground connections? Did you pinch any harnesses during the swap?
Old Mar 15, 2014 | 03:21 PM
Renier's Avatar
Car: '89 Camaro RS
The battery sparks when the post is touched, that's what I mean, meaning it's not empty. But thanks for the suggestions! Checked all ground connections they're all connected. Don't think I pinched any harnesses, can't think of which one would've been pinched.
Old Mar 17, 2014 | 05:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Power This Hour
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the 12 gage pink wire out of the steering column when the key is in the RUN position.
Is there power there?
Happy Racing !
Don’t Blame Me For Spinning Him, My Car Simply Took The Air Off His Spoiler
Old Mar 17, 2014 | 07:26 PM
Joe Tag's Avatar
Sounds a lot like it would be the fusible links at the starter, possibly ground strap on the passenger side head to the firewall.
Old Mar 20, 2014 | 09:09 AM
Renier's Avatar
Car: '89 Camaro RS
Thanks a lot, guys! Problem is solved, it was the wire on the starter after all.
Old Mar 20, 2014 | 09:25 AM
Joe Tag's Avatar
Glad to hear you got it sorted out.
Old Mar 20, 2014 | 06:52 PM
Lurbie's Avatar
Car: 89 Camaro
Glad you figured it out!
Elephantismo
Feb 13, 2019 12:51 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
indygene
Sep 26, 2015 11:21 AM
327IROC85
Sep 23, 2015 12:11 AM
dimented24x7
Sep 17, 2015 06:58 AM
