Driver and Passenger Courtesy Lights Not Turning Off When Door is Closed
Old Mar 18, 2014 | 08:23 PM
FL TA's Avatar
Car: 1985 Pontiac Trans Am WS6
Transmission: 4 SPD AUTO Borg Warner 9 Bolt
My 85 TA driver and passenger courtesy footwell lights are staying on when both doors are closed.
Am I correct to assume its the door jamb switch? Or would it be something else?
Assuming its the door jamb switch, anyone know how to swap this out or where to obtain a new pair for each door?
Thanks!
Old Mar 18, 2014 | 08:37 PM
Joe Tag's Avatar
Re: Driver and Passenger Courtesy Lights Not Turning Off When Door is Closed
Ok, this may sound stupid, but first check that the instrument cluster dimmer switch is not locked in the max position. This will turn the interior lights on. If that's not the case, pull the kick panels and unplug the door switches one at a time and close the other door to figure out if it is one of the switches. If that isn't the case you will have to dig deeper. I would then start by unplugging the aforementioned dimmer( I believe it is separate from headlight switch on a bird) From then, it will be a little more involved with a voltmeter and testing for the white wire for door switches skinned or grounded somewhere.
Old Mar 19, 2014 | 11:10 AM
FL TA's Avatar
Thanks for the response Joe Tag.
I did check the dimmer switch. It was not turned to max.
After checking out this thread (the exact opposite of what I am experiencing):
https://www.thirdgen.org/forums/inte...-courtesy.html
I decided to order a pair of door jamb push switches from GM Parts Direct.
I'll put those on and report back if that fixes my issue (fingers crossed).
Old Mar 20, 2014 | 09:54 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I am pretty sure that it is the door jamb switch in your case. The switch cuts off ground to the lights when you close the door. Since they dont turn off they are constantly being grounded. In some models it also affects the chime for the key in ignition switch (if you have the audible alarm RPO code). I had to replace my stock door jambs after my car came from the bodyshop. I went with the switches from classic industries. They have a plastic tip so it doesn't scratch the doors. I am not sure if you would be able to use them because they are one terminal. I don't know if your 1985 t/a was two terminal. For me it didn't matter because I installed a body control module from an 01 bird. However the switches are of excellent quality, and they do not scratch the doors unlike the metal ones. Not sure what you're getting, but that's my two cents.
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
BlackTopKing
Aug 19, 2015 12:13 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
