hvac connector pin outs (91 4 wire)
Old Mar 25, 2014 | 06:24 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Any one have pinouts for a 91 4 pin hvac connector (engine bay)?
Pin color function
a- lt blue
b- red- battery-on fuse able link
c- green white strip
d- black-ground
Old Mar 30, 2014 | 04:14 PM
SansKey's Avatar
Former Sponsor
Re: hvac connector pin outs (91 4 wire)
I just looked in my 92 manual. The Light Blue goes from the Pressure Cycling Switch to the A/C High Pressure Switch. I haven't seen anything about the Green/White, though. Ima keep looking, however.
Old Mar 30, 2014 | 04:24 PM
SansKey's Avatar
Former Sponsor
Found it. Dark Green/White goes from the coil of the coolant fan relay to the A/C Control Head (the thing in the car where you choose Max, Vent, etc).
The whole circuit is: Fan Fuse, Coolant Fan Relay, A/C Control Head. When you choose Max, Norm or Bi-Level, it completes the circuit to ground and causes the Fan Relay to switch on, and therefore turn on the fan.
Old Mar 30, 2014 | 05:28 PM
Car: 91 z28
Transmission: 4L60e
Thank you Sir. It is interesting to note that the factory schematics never show the green/white wire on the connector. It looks as if the connector is labeled as C105.
Old Mar 30, 2014 | 05:37 PM
SansKey's Avatar
Former Sponsor
Yea. It is C105. I found the green/white wire in the Coolant Fan schematics.
Old Oct 28, 2015 | 08:39 PM
Car: 91 z28
Transmission: 4L60e
VIN E (TBI) (coolant fan circuit)
http://www.austinthirdgen.org/mkport...an_V8_vinE.jpg
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Casey Meyers
Mar 2, 2016 10:46 AM
