External AC Diode?
Old Mar 26, 2014 | 03:02 PM
ronkay's Avatar
External AC Diode?
Hi All,
I'm in the early stage of restoring a 92 RS 305 TBI and have a question. I came across a two conductor electrical connector that is completely fried located in the front of the engine in the same wiring harness as the AC. But there is no place I can find to plug it in? Haynes wiring diagram does not show anything remotely close to this...
Can an this be an external diode for the AC compressor?
Thanks,
Ron
Attached Thumbnails External AC Diode?-img_0647.gif   External AC Diode?-img_0646.gif   External AC Diode?-img_0645.gif
Old Apr 1, 2014 | 04:51 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Diode Abode
Originally Posted by ronkay
………connector………Can an this be an external diode for the AC compressor?
No. The diode is spliced and taped in place from the factory.
Happy Racing !
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
Old Apr 1, 2014 | 09:11 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: External AC Diode?
Looks like that is the connector busted off of a clutch. Disconnect it and command the AC on while you have a test light connected to this connector. My bet is it will light up when you command the AC on.
Old Apr 4, 2014 | 09:56 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
correct, the diode is the black tube about 3" rearward of the connector. The only fix I know is a new A/C compressor.
Old Apr 5, 2014 | 11:02 AM
ronkay's Avatar
Lurbie,
The system is not charged so can I still command the AC on and do the diagnostic as you describe?
Old Apr 5, 2014 | 01:50 PM
ronkay's Avatar
Thanks to all for your help. The mystery has been solved. The connector is indeed the one that goes to the clutch on the front of the compressor. It actually took a second set of eyes to point that out to me...
Thanks again for the help.
Ron
Old Apr 5, 2014 | 03:47 PM
Lurbie's Avatar
Car: 89 Camaro
Lurbie,
Glad you got it figured out. To answer your question though, yes you could still test it the way I described, but you would have to temporarily disconnect the Low Pressure Cutout switch and bypass it with a jumper wire on the harness connector.
Old Apr 5, 2014 | 04:58 PM
ronkay's Avatar
Super. Thanks agin for the information....
morrow
Members Camaros
196
Jan 13, 2024 12:21 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
Hello, Michael
Sep 11, 2015 01:10 PM
lakeffect2
Sep 7, 2015 03:52 PM
