No Electrical?!?
Old Apr 21, 2014 | 12:10 AM
RStein's Avatar
Car: 1989 Firebird Formula 350
No Electrical?!?
When I got my car the battery in it was dead and I needed a new starter. So I took the batter out and put it on a trickle charger while I replaced the starter. Before I took the battery out the dome light would come on and the dash would light up. Now after I put the new starter in and hook the charged battery up, I HAVE NOTHING?!? I have no dome lights, no dash lights, nothing electrical. Tried Jumping the battery, different batteries but still nothing. HELP!
Old Apr 21, 2014 | 04:41 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: No Electrical?!?
Go back and check the starter to make sure you didn't miss a wire. Another member just had the same thing happen to them.
https://www.thirdgen.org/forums/elec...ltage-all.html
Old Apr 26, 2014 | 07:56 AM
RStein's Avatar
Thanks, it was a missed wire on the starter. New problem is the starter wont engage when the key is turned.
Old Apr 26, 2014 | 12:16 PM
Zeifer's Avatar
Car: 1988 Chevrolet Camaro IROC-Z
Engine: 408 LSx
Transmission: T56 Magnum
Axle/Gears: 3.73 10-Bolt Detroit TrueTrac
If the lights dim and everything, check the neutral safety switch. I thought my starter was bad once, swapped it with a new selenoid, bypassed fusable links, etc. Had to pop start the car for 2 days. Turned out my switch was unplugged.
Old Apr 28, 2014 | 11:45 PM
RStein's Avatar
Thanks for the help.
Wiring a push button start on the car temporarily. Just going to run a new wire to the terminal and a positive off the battery to the push button. Should work better than using a screwdriver to jump the positive on the starter to the power lead.
1992Z28!
Nov 19, 2015 07:33 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
lanceflame44
Sep 25, 2015 12:28 PM
