Accidentally shorted my fuel pump fuse, help!
Old May 4, 2014 | 05:23 PM
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
I was fixing a secondary fan issue at my relay bracket, and accidentally shorted across the relay for my fuel pump. Where is the fuse? According to my Haynes manual it's in the fuse block, but where the manual says there's a fuel pump fuse, there isn't in my fuse block. There are two 30 amp fuses that are jacketed in metal, and I can't tell if they're blown. Could it be one of them? I'm running the 5.7 tpi L98. This is the dumbest thing I've done so far this week, but it's past praying for now. I did fix the fan problem though......
Old May 4, 2014 | 05:48 PM
Engine: 5.7L T.P.I.
Re: Accidentally shorted my fuel pump fuse, help!
Never mind....found it. It's at the end of a wire near the battery with a plastic pop top thingy. Right where you'd expect it to be.....sheesh....
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
