Voltage gauge bouncy
Old May 12, 2014 | 08:31 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
The voltage gauge in my 85 Camaro works fine when the car is cold. Once the car/engine/interior warms up the gauge will sometimes read at 13 volts or drop down to near the bottom and stay there.
I have replaced the gauge and the exact same thing happens. The cluster has been out a few times to replace bulbs and it seems to be securely fastened.
Where does the voltage gauge get its signal from?
I should note that a voltage tester on the battery terminals show a constant voltage when the gauge is going up and down.
Old May 12, 2014 | 09:13 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Voltage gauge bouncy
It comes from the 10A Gages fuse. It's a Pnk/Blk wire at the cluster. It powers your coolant temp, oil press. and Tach gauges. Are any others bouncing around or reading inaccurately?
Old May 12, 2014 | 09:52 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
All the other gauges work fine. Oil pressure rises and falls with engine speed but that is a different story.
The voltage gauge has been going up and down even with 2 different alternators.
Old May 12, 2014 | 10:27 PM
Lurbie's Avatar
Car: 89 Camaro
I'd pull the cluster and check voltage at the gauge itself, when it happens substitute a known good B+ source and a known good ground source to see if you've got a bad B+ or bad ground to the gauge or just a gauge problem.
Bubbajones_ya
Jul 6, 2024 08:32 PM
KCG
Jun 24, 2020 04:33 AM
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
