Fuel pump HELP PLEASE
Old Jun 4, 2014 | 12:05 AM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Ok its a 88 IROC 5.7 TPI car that was converted to carb. now restoring entire car back with TPI..No power on the ECM green/wht 12v? No result with the fuel pump test at the ADL. New fuel pump. I put 12v to the Tan/wht wire that goes from the fuse block to the FP and the FP runs that way. I have power to the oil pressure Tan/wht and i forget the other color wire Brown? Put it wont Prime! fuses are checked but i dont have one near the battery? am i missing that? Please help so i can get it to the painter
Old Jun 4, 2014 | 04:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Fuel pump HELP PLEASE
The fuse by the battery powers the fuel pump and the ECM. If it's missing it was probably deleted by the guy that changed it to carb.
Did the carb setup run on a mechanical fuel pump and you put the new fuel pump in the tank in order to restore it to TPI?
Old Jun 4, 2014 | 04:43 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The ECM should have constant 12V at the orange wire on pin B1 fed by that fuse near the battery. The fuel pump relay wire you are talking about is an output for 2 second prime/cranking/running.
Old Jun 4, 2014 | 08:40 PM
mjdavis68's Avatar
Ran the OEM pump with a regulator so thats why i changed it.
Old Jun 4, 2014 | 08:43 PM
mjdavis68's Avatar
Yes it does have power on the orange, so if i place a test light on the Green/wht wire and turn the key i should see a light for 2 seconds? if not then what?
Old Jun 12, 2014 | 08:26 PM
mjdavis68's Avatar
Ok today i pulled all the wire loom off the engine harness so can trace these dang wires-
I have a single Black/White wire thats cut- the main single wire from the ECM i guess, turns into a soldered bundle over by the Firewall that 1 goes to the engine block 2 goes to the fuel pump relay 3 goes to the maf burn off relay next to the fuel pump relay and the other is the one thats cut! can anyone tell me if this is where they actually go and where the other one thats cut goes please?
Thanks to anyone
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
