Correct original positive battery cable
Old Jul 3, 2014 | 11:46 PM
92GTA's Avatar
I'm trying to find GM 12157285. It's the positive battery cable that is a 1-piece and Ys off to the alternator and starter.
GM lists it disco and I can't seem to find a *correct* replacement online. They are all black cables or don't have the correct shaped battery connector.
Someone at some point mentioned to me the ACDELCO replacement is 4SD35XA but that can't be it, it's not even correct for going to the alternator and starter, never mind it's black instead of red too, errrrr, who the **** makes a black positive battery cable!
Anyone know where to get these? I want it either NOS or EXACTLY like it was originally please. I had an NOS one and like an idiot I sold it a few years ago
Any leads I'd really appreciate it! I've emailed Hawk's twice and they won't respond for a used one
Old Jul 4, 2014 | 01:14 AM
s10sbc350's Avatar
Car: 91 Z28 camaro
Engine: L98 from 90-92 camaro
Re: Correct original positive battery cable
I'll sell you my used one If you want a origonal one that goes to alt and starter that bad LMAO... $30
Old Jul 4, 2014 | 01:23 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
http://www.rockauto.com/catalog/more...403&cc=1035627
Old Jul 4, 2014 | 01:32 PM
92GTA's Avatar
See even that one is black and not right
I'm wrong though, it only goes to the alternator from the battery and to that other connector, so that is the right cable physically, just not the right color.
Old Jul 4, 2014 | 09:22 PM
s10sbc350's Avatar
Car: 91 Z28 camaro
Holy crap I have never seen someone so **** about something as dumb as a red battery cable. I understand you don't wanna mix the pos and neg cables but come on man... Put a label on it or wrap it in red electrical tape man.
Old Jul 5, 2014 | 02:18 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I have never seen an original GM positive battery cable that is/was red. Only the protective cover surrounding the terminal is red.
I believe that the red terminal cover can be removed from the cable once the bolt is removed. It appeared that this was the case when I replaced a stripped battery terminal bolt on mine.
If you have your old cable you can just remove the cover and swap it onto the new cable. If you don't have your old cable it should be easy enough to find one at the salvage yard. Most all GM cars came from the factory with red terminal covered cables. Just bring your cable cutters with you.
Old Jul 7, 2014 | 05:15 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Color Me Gone !
You can spray it a product called ‘PlastiDip’.
They have it in several
colors including the
red you are looking for.
It is a rubber-like coating that will not peel, crack or deteriorate, and it will add to the insulation value.
Happy Racing !
Make Noise, Turn Left, Repeat
Old Jul 8, 2014 | 07:52 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Dude - that ain't NUTHIN' !! People are CRAZY about their rides !
Once; I saw this guy literally jump in the air when he found the 'correct' fuel line clips for his ride at a swap meet. "Factory original" doesn't mean the same thing to everyone !
.........Anyone know where to get these? I want it either NOS or EXACTLY like it was originally please. I had an NOS one and like an idiot I sold it a few years ago Any leads I'd really appreciate it! .............
NOS - NO clue. I'd keep watching E-Bay with my fingers crossed !
I might have a used one too. There were at least 4-5 different battery cables used over the years. At the least I'd need a picture of yours to compare and a couple measurements would help too.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Bryan F
Aug 18, 2015 02:28 PM
Vintageracer
Aug 11, 2015 08:13 PM
