Engine harness???
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Engine harness???
I really kinda' does,..... 5.0 could be a carb, TPI, or MPFI.
It's important to not only ask for the right TYPE of engine harnesss that you need, but it's also VERY important that you get the one for the correct YEAR of the Thirdgen your working on. While engine harnesses are similar from year-to-year, "engine" harnesses are NOT the same.
The stock 87 Camaro had an ENGINE harness AND an ECM harness ( 2 different / seperate harnesses ) . What 1 are you trying to locate ??
Be specific, getting the RIGHT harness - the first time - will make things a LOT easier for you !
Sanjay
Aug 12, 2015 03:41 PM
